Flat bottom design per API620
Hi everybody!!
I need to design a flat-bottom tank without counterbalancing weight, per API620. Code states the method shall be a matter of agreement with purchaser.
Do you know any method to do this? it is a 162" diameter and 42' height tank, with internal design pressure of 10 psig. I got reference from an identical tank that has a bottom plate thickness of 1.25".
I don't want to use ASME since tank code must be API620 and checking thickness as per ASME I would need near 2" (flat unstayed plate).
Somebody can help me? even ideas are desired.
Tanks a lot!!!!
Heyner.
Tanks a lot!!!!
Heyner.
RE: Flat bottom design per API620
Flat bottom for pressure vessel
Thread794-46942
ETank: Tank design software per API-620, API-650, API-653, UL-142, and API-2000.
http://www.etank.com/
Leonard@thill.biz
www.thill.biz
From-- Structural Engineering Handbook:
Section 23 “STEEL TANKS”
John N. Pirok** and Robert S. Wozniak**
*Chief Structural Engineer and **Design Engineer Chicago Bridge & Iron Company, Oak Brook, Illinois
Edited by Edwin H Gaylord, Jr. Professor of Civil Engineering, Emeritus, university of Illinois, Urbana
Charles N. Gaylord, Professor of Civil Engineering, University of Virginia
Leonard@thill.biz
www.thill.biz
