BUG ALERT--exporting to parasolid
I have found a serious bug in SW2003 SP1.0.  I will be notifying SW.
We had exported a set of SW files to parasolid.  Each of these files contained a surface model that was suppressed and a solid model that was not.
The translation had exported the suppressed bodies without notification.  The result was that our tool vendor almost built tools to the wrong body.
I have been forced to select individual bodies prior to export, even if extra bodies are suppressed.
Sanity! You're a madman!
RE: BUG ALERT--exporting to parasolid
I'll be loading the latest SP after the weekend.  Meantime, it seemed like something people oughta know about.
I have heard about this before in the newsgroup.  I believe it has been fixed with one of the latest service packs..
Just tried exporting and then reimporting a part with solids and suppressed surfaces and it seemed to work fine.
SWX2003 SP3.1
I just tried this on SW2001.  No problem there.
I was lucky to find out when I did.  We had sent our tooling vendor an updated model, and when he reviewed the changes, it turned out that he would have built to the wrong model!
Yea,
Scott B wrote:
>It sounds like your problem will be resolved if you >upgrade to a newer SP than 1.0.
But, what will he get in "trade". That is the question.
Sean F
seanf@newing-halll.com
1 2 many l's in email
Sean F
Mechanical Engineer
1 2 many l's in e-mail
I'd just like to add that exporting a parasolid of a part file with suppressed features in SW03 SP1.0 works as expected (which is a good thing).
I don't work much with surfaces, but does it matter if you save as parasolid .x_t format or parasolid binary .x_b format?  Do the suppressed surfaces still get exported?
Wanna Tip? FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
