UK Material BS3602/35
Does anyone know the spec (Chemical and mechanical properties)?
RE: UK Material BS3602/35
BS3602-1/360 equivalent to SA/A106 GR A, DIN 1626-st. 35.8, STPG370
TEN. 360~500 N/mm2
YIELD MIN. 215 "
ELONGATION MIN. 24%
C 0.17 MAX
Si 0.35 MAX
Mn 0.4~0.8
P 0.045 MAX
S 0.045 MAX
Hi, aobjr:
Thanks for your input, but BS3602 Grade 35 might be an out of dated standard, and I'm pretty sure that it is different with BS3602-1/360. Can you check it out again from your handbook?
I think your material specifiction is based on old standard.
Based on my data FROM LOWER GRADE TO HIGHER GRADE:
BS3601-360(SA/A53GRA,DIN 1626-st.35,STPG370)
BS3602-360(SA/A106GRA, DIN 17175-st.35.8,STPT370)
BS3602-410(SA/A106GRB, DIN 17175-st.45.8,STPT410)
BS3602-460(SA/A106GRC,STPT480)
HOPE ITS CLEAR TO YOU.
