Weld Root Corrosion in Production Pipework
We are suffering from very severve weld root corossion in LTCS A333 gr6 production pipework. The latest to fail has only been in service for 18-24 months. The concensus of opinion is that the 1% nickel in the welding consumable is the prime cause.
The pipework should no signs of corossion, but the welds coroded to the point of leakage.
Any ideas appreciated, we are currently replacing the pipework with like for like so will probably be re-visiting the problem in 18 months time.
RE: Weld Root Corrosion in Production Pipework
In the past, we have had problems with preferential root weld corrosion, in API 5L crude oil production pipework. After around 1 year of investigation in 80 wells, we found that the most possible cause was a combination between the fluid erosional velocity and the CO2 presence. The problem was minimized adjusting some variables, such as: CO2 corrosion inhibitor selection with high "shear stress", increasing corrosion inhibitor dosage, increase the chemical injection system availability. And in some cases, we replaced the pipework for a largest diamater one. Additionally, END procedures (Gamma-Ray and TOFD) were developed to allows us a close monitoreo, that us of data to make for fitness for service analysis.
it sounds like knife edge corrosion at the HAZ due to diferential cathodic attack started by the slight change in metallurgy Weld - base metal
