Charts for Yeild stress of Bolts
Charts for Yeild stress of Bolts.
I am trying to determine the minimum size ARP2000 or similar quality bolts I can use, for a 4 bolt con rod design, which is being used to substitute for a 2 bolt design useing 1913 vintage 5/8" UNF bolts.
A chart that shows root dia or min cross sectional areas for various UNF bolts would help, as would a chart of ultimate tensile strengths for various size and grade bolts.
I don't have acces to a machinists handbook. Maybe I need one, but in the meantime can anyone help
pat
RE: Charts for Yeild stress of Bolts
http://ourworld.compuserve.com/homepages/MJVanVoorhis/T205.htm
Also check out some of the other info there.
Regards, Pat
That's exactly what I needed
pat
