Lightweight steel framing system
I will use lightweight joist construction for a residencial project. Since my joists are 12" o.c. I am using a form deck UFS 9/16" thick and 2 1/2" slab. This gives a capacity of 480psf for a single span. However i have seen residential construction where for the same application people are using 1 1/2" deck plus 4" slab. Is there a reason for this?
RE: Lightweight steel framing system
