Multiple select in AutoLisp
Does anyone know an easy way to select multiple objects using AutoLisp, in a way that is simlar to an AutoCAD select box. I need to use it in a scale program, to adjust a drawing after it has been created.
I know that you can select points on each line, but I am looking for a simple way.
kabluzy
kabluzy
RE: Multiple select in AutoLisp
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
