AutoCAD 2000 to 2004 - AutoLISP Insert into Dialog Boxes...
In R2000, I could use this line of LISP code...
(command "-insert" "bill_note_left" P4 (* (getvar "dimscale") 1) "" "0" AttReq AttRSP JOB+PTSQ2 AttRev AttRelBy AttRelDate AttDesc AttMfg AttMisc AttCode SNStr LN AttIMNO AttIMDESC IN) ;; insert block with attributes
In R2004, once it hits the attribute the code stops...
(command "-insert" "bill_note_left" P4 (* (getvar "dimscale") 1) "" "0" ...
Any remedies to this?
RE: AutoCAD 2000 to 2004 - AutoLISP Insert into Dialog Boxes...
I don't have a clue to your problem, I'm just curious.  Why are you multiplying the DIMSCALE times 1?
Great question.  I have no idea.  This program was written three years ago when we upgraded to 2000, and I have no idea why I wrote it this way.  It does however, work in 2000.
Check TEXTEVAL.  I'm assuming you're assigning values to ...
Wait a minute, are you aware that ATTREQ is an AutoCAD system variable?  Are you resetting it to a variable within your lisp function?
... anyway, TEXTEVAL determines how autocad text functions evaluate strings in commands.
The attdia variable is a little touchier in 2004 vs 2000!
