some problem about VSWR (HELP!)
I just do not understand an expression about VSWR. It is about something is defined as 1:2.5 VSWR.....I dont know what do it mean. Is that means VSWR=2.5 ??? or other meaning?
Pls help!
Raymond
Pls help!
Raymond
RE: some problem about VSWR (HELP!)
vswr = 20 log (Vpk/Vo) where Vo is the voltage at matched conditions.
you get mis-match when there are impedence discontinuities on the line.
a matched source-load has a vswr of unity.
VSWR < 2.0 is OK, best VSWR is 1.
(maximum RMS voltage)/(minimum RMS voltage)
where the maximum and minimum voltages occur at different points along a particular transmission line. It should be obvious from this definition that the ratio can never be less than 1.
The expression 1 : 2.5 as a VSWR is incorrect and might have been intended to be 2.5: 1.
2.5:1 as a VSWR is ordinarily simplified to 2.5
