joining of alumina
joining of alumina
What is the right way to join alumina to alumina?
Is brazing possible? Or welding? Diffusion welding?
Anything else?
Anything else?
RE: joining of alumina
Tom
Is there a way?
Alumina purities above 92%
Thanks in advance
If you can tolerate a thin interface of a few thousandts of an inch of metal, the Moly-Manganese metalllizing process will give you as much as 9,000 psi tensile strength. I can give most of the processing details if you are intereted.
Jesus is THE life,
Leonard
I think that is the way to get a monolytic alumina, but I'm searching for information about it.
I did a word search for glass frits on this forum and came up witht this thread so I did a Google search and seletcted a few links that might lead you to something:
http://www.cyberexports.com/prodbuysell.asp?Opt=B&pname=Glass+frits+a+d%20powders&QS=(Buyers.PRCODEN+LIKE+'320740*')
http://www.glasschange.com/equip/equip_115.html
http://www.urbansky.com/usingnorthstarfrit.htm
Jesus is THE life,
Leonard
Yes, brazing is very doable.
the joined Alumina parts have to be gas tight.
The mean point is to get monolytic material.
1) By monolithic, I assumed you wanted the same material throughout (Alumina in this case). But if you simply mean one contiguous piece then JimMetalsCeramics suggstion might simplest if it provides the properties you need.
2) The Mo-Mn process mentioned in my June 27 post, will give you leak tightness of 1 x 10^-8 cc/year leak rate of Helium. Also note the high tensile strength attained with the Mo-Mn process.
Jesus is THE life,
Leonard
As said in your first point metman, I want the same material throughout for a semiconductor application. Metal may not be used in this application. What is possible
For an other application where leak tightness is important, sounds the Mo-Mn process interesting. I can tolerate a thin interface of a few thousandts of an inch of metal. Refering to your post June 27, wat are most of the processing details?
-active metal brazing or,
-joining with a glass layer.
In either case, you apply a powder-filled ink to the joint and heat the parts together.
35/65 Copper Alloy in a Vacuum furnace
Wesgo is the company that sells brazing
alloy out of California. They also have a rep
in Milwaukee, Wisconsin.
If you need more info you can call me
at 312.777.4943
Andy
