Gas consumption rate
"what is the fuel consumption rate in m3 /hr for an 100 KW gas fired generator set"
RE: Gas consumption rate
There is no reliable accurate answer to your question with the limited information that is provided.  You should be able to calculate the fuel consumption rate from the specified efficiency or heat rate for the unit.
