Forces on Flat Plate in Compressible Fluid Stream
If I have a flat plate oriented normal to the fluid stream and then rotate it +/- 45deg, is the new force imparted onto the plate basically equal to F45 = L*cos(45)*Fnormal?
RE: Forces on Flat Plate in Compressible Fluid Stream
yep sounds correct to me.
