Forces on Flat Plate in Compressible Fluid Stream
If I have a flat plate oriented normal to the fluid stream and then rotate it +/- 45deg, is the new force imparted onto the plate basically equal to F45 = L*cos(45)*Fnormal?
RE: Forces on Flat Plate in Compressible Fluid Stream
Oops.
I just realized that I posted this in the wrong area.
Pls forgive the error...
Hi gittings00
I haven't got formula's here for a compressible fluid
but for a jet of water acting on a plate at an angle the formula is :-
   F= pAV^2*(Cos (x))
where p = density of fluid
      A = cross sectional area of jet
      V = velocity of fluid
      F = force normal to the inclined plate
hope this helps
regards
desertfox
