select by ray API
select by ray API
select by ray API
Hi all
has anybody tried to select entities using ModelDoc2:RayIntersections or ModelDoc2:multiselectbyray API's?
I am finding some problem with it and am not able to trace it. The code is given as below... Also does anyone know how to handle exceptions coming from solidworks or get info about these?
What I am trying to do is I get box on the main part body. then I fire a ray from center of one of the face towards the body and try to select all the faces in between. but it's not working.. if anybody has pointers please let me know.
thanks
   Set actDoc = solidModeler.ActiveDoc
    If actDoc.GetType <> swDocPART Then
        Call MsgBox("Only Allowed on Parts", vbOKOnly, "Error") ' Display error message
        Exit Function ' Exit this program
    End If
    ReDim boxParams(6)
    Set bodyObj = actDoc.Body
    If (bodyObj Is Nothing) Then
        solidModeler.SendMsgToUser "Error! Part has no body."
        Exit Function
    End If
    boxParams = bodyObj.GetBodyBox()
    If Not (IsEmpty(boxParams) Or IsNull(boxParams)) Then
        For i = 0 To UBound(boxParams)   ' For each string in the SafeArray
            boxParams(i) = boxParams(i) * 100
            Debug.Print boxParams(i)
        Next i
    End If
    ln = boxParams(3) - boxParams(0)
    wd = boxParams(4) - boxParams(1)
    ht = boxParams(5) - boxParams(2)
    zUpper = boxParams(5)
    yUpper = boxParams(4)
    xUpper = boxParams(3)
    zLower = boxParams(2)
    yLower = boxParams(1)
    xLower = boxParams(0)
    Dim rayOrigin(3) As Variant
    'Dim org(3) As Double
    Dim rayDir(3) As Variant
    rayOrigin(0) = xLower + ln / 2
    rayOrigin(1) = yLower + wd / 2
    rayOrigin(2) = zLower - 1
    rayDir(0) = 0
    rayDir(1) = 0
    rayDir(2) = 1
    Call RayFire(rayOrigin, rayDir)
    Set bodyObj = Nothing
    Set actDoc = Nothing
End Function
Sub RayFire(origin As Variant, dir As Variant)
    Dim hits As Integer
    Dim bIn(0) As Variant
    Dim params(7) As Variant
    Dim res As Boolean
    Dim i As Integer
    Set bIn(0) = actDoc.Body
    params(0) = origin(0)
    params(1) = origin(1)
    params(2) = origin(2)
    params(3) = dir(0)
    params(4) = dir(1)
    params(5) = dir(2)
    params(6) = 0.1
    For i = 0 To 7
        Debug.Print "param " & i & " : " & params(i)
    Next i
    res = actDoc.MultiSelectByRay(params, swSelFACES, False)
    Debug.Print res
    res = actDoc.SelectByRay(params, swSelFACES)
    Debug.Print res
/////////////the below code throws some unknown error to me...
    'On Error Resume Next
     '   MsgBox ("Error # " & CStr(Err.Number) & " " & Err.Description)
    'hits = actDoc.RayIntersections(bIn, origin, dir, 2, 0.01, 0.01)
    'Debug.Print "hits " & hits
End Sub
