MODELING MOVING LOAD WITH ABAQUS
Hi Everyone,
I am trying to model a moving wheel load on a surface using abaqus. The problem consists of modeling a tire and surface and proviidng contact between then, while giving tire an initial rotation.
Since modeling a tire with tire pressure itself is a tough job, I tried to get an initial rough model by modeling the system as moving pressure load over a surface. The model is: a pressure load of fine extent is moving at constant speed on a surface. How do I model this in Abaqus? When I give load information in STEP module, I select a region where the laod is acting. But the region will not be fixed, it will change in next time step as the load moves on. How can I model this?
Any response is greatly appreciated. Thanks.
Sudip
Sudip
RE: MODELING MOVING LOAD WITH ABAQUS
