How the estimate a part weight in Proe?
Hi, all,
    This is Raby.
    Here I have a question: how to estimate a part weight in proe? I have some idea that in "set-up", there's some order to do, but I really have little knowledge about this function. Could you give me some detail instruments? Thanks.
RE: How the estimate a part weight in Proe?
raby,
Use the following menu picks:
#Analysis; #Model Analysis
Select Model Mass Properties from the pull down menu (should be the default).
Select Compute
You can store this calculation as a feature as well.
Best regards,
Matthew Ian Loew
Ravi,
make sure you assign the corresponding density of the material to calculate the weight.
To set the density:
#Set up #Density
Be sure to put the appropriate density for how your model units are set.
Many thanks for all of you!
