need better method of determining solar irradiation
I was wondering if anyone knows of a better way to determine the solar irradiation, at the Earth's surface, than with using ASHRAE's ClearSky Model, which uses a Cn constant to approximate the solar flux?
If you know of any, and are almost as simple to use as the ASHRAE model, I would very much appreciate any sources you could give me.
Thx
RE: need better method of determining solar irradiation
Have you tried HICKS Standard Handbook of Engineering Calculations (McGraw-Hill) Section Two, Architectural Engineering, Solar Engineering ? The chapter's bibliography appears to include ASHRAE's handbook but others as well.
To answer your question I need to know more about what you're trying to do.
Tunalover
Thanks for your replies.
25362, that book is pretty good.  I have another called gieck and gieck (or geek and geek).
tunalover, basically I have a 1.2m parabolic dish and I'm trying to determine what the maximum useful energy can be extracted from this device.  It's like a 2nd law efficiency.
Mintjulep,  I found something very similar from the nasa website.  It gives the maximum and the average values of solar insolation at any location on earth.  Thank you, though , for your reply.
You can also try MIL-STD-810F, which in Method 505.4-14 shows the 99-percentile diurnal solar radiation load.  The other is MIL-HDBK-310, which has a smidgen more data about lesser percentiles.
TTFN
