Cooling tower design, any experts?
Hi everyone, I work on an oil refinery and have recently been asked to evaluate and improve the cooling water system on our gas oil Hydrodesulphurisation plant, I haven't had much to do with cooling water systems but have quickly got myself up to speed.
In order to evaluate the current towers as a first step I will compare heat load and cooling range with the manufacturers specs, problem is we have 2 tower units of which both have seperate returns from the process at different temperatures and the water falls into a common pond beneath the towers so is the only way for me to gather data to take manual temperature readings of the water leaving each unit? Or is there a way to evaluate heat load and cooling range using the common cooling water pond outlet temperature?
I have all other info flows, temperatures etc and can calculate the heat load going to each seperate unit but with the common pond below I cannot get the water temperature leaving each tower unit (should I just do this manually?)
Sorry for the long winded question but I just can't get my head round this (more of a chemistry man) thanks very much for any help.
Steve
Steve
RE: Cooling tower design, any experts?
You should get a copy of the ATP 105 issued by the Cooling Tower Institute. There are the basis for the evaluation of a cooling tower, but anyway you will have some problems because of your installation.
