pro program how to turn a local group off?
i have created a local group in a prt file consisting of three protrusions. i want to be able to turn it on and off as desired using pro program. I have gone back to basics with these 3 protrusions but i still maintain to get errors!
below is a copy of the statements in pro program including where the errors highlight.
Please can you tell me where im going wrong?
(local group=shapes)
many thanks,
VERSION
REVNUM 164
LISTING FOR PART TEST
INPUT
include_prot yes_no
"protrusion yes no?"
END INPUT
RELATIONS
END RELATIONS
ADD FEATURE (initial number 1)
INTERNAL FEATURE ID 1
TYPE = DATUM PLANE
NAME = RIGHT
FEATURE IS IN LAYER(S) :
01___PRT_ALL_DTM_PLN - OPERATION = SHOWN
01___PRT_DEF_DTM_PLN - OPERATION = SHOWN
END ADD
ADD FEATURE (initial number 2)
INTERNAL FEATURE ID 3
TYPE = DATUM PLANE
NAME = TOP
END ADD
ADD FEATURE (initial number 3)
INTERNAL FEATURE ID 5
TYPE = DATUM PLANE
NAME = FRONT
END ADD
ADD FEATURE (initial number 4)
INTERNAL FEATURE ID 7
TYPE = COORDINATE SYSTEM
NAME = PRT_CSYS_DEF
05___PRT_ALL_DTM_CSYS - OPERATION = SHOWN
05___PRT_DEF_DTM_CSYS - OPERATION = SHOWN
END ADD
if include_prot==yes
add part prot
ADD FEATURE (initial number 5)
!*** ERR: no END ADD statement for ADD on line 0
INTERNAL FEATURE ID 99
GROUP HEAD
NO. ELEMENT NAME INFO
1 Name Defined
2 Features Defined
3 Construction Defined
NAME = SHAPES
FEATURE BELONGS TO LOCAL GROUP SHAPES
MEMBER OF A GROUP, NAME = SHAPES
LEADING FEATURE OF THE GROUP: ID = 99
LAST FEATURE OF THE GROUP: ID = 79
END ADD
!*** ERR: unmatched END statement encountered
ADD FEATURE (initial number 6)
INTERNAL FEATURE ID 39
PARENTS = 3(#2) 5(#3) 1(#1)
PROTRUSION: Extrude
NO. ELEMENT NAME INFO STATUS
1 Attributes One Side Defined
2 Section Sk. plane - Surface RIGHT of feat #1 (DATUM PLANE) Defined
3 Direction Defined
4 Depth Blind, depth = 126.501 Defined
SECTION NAME = S2D0001
FEATURE'S DIMENSIONS:
d1 = 177.36 (weak)
d2 = 15.68 (weak)
d3 = 77.20 (weak)
d4 = 126.50
END ADD
ADD FEATURE (initial number 7)
INTERNAL FEATURE ID 57
PROTRUSION: Extrude
2 Section Defined
3 Direction Defined
4 Depth Blind, depth = 108.892 Defined
SECTION NAME = S2D0002
02___PRT_ALL_AXES - OPERATION = SHOWN
d5 = 30.00
d6 = 93.26 Dia (weak)
d7 = 72.64 (weak)
d8 = 123.26 (weak)
d9 = 108.89
END ADD
ADD FEATURE (initial number 8)
INTERNAL FEATURE ID 79
PROTRUSION: Extrude
2 Section Defined
3 Direction Defined
4 Depth Blind, depth = 125.487 Defined
SECTION NAME = S2D0003
d10 = 60.00
d12 = 189.15 (weak)
d13 = 18.94 (weak)
d14 = 112.59 (weak)
d15 = 125.49
END ADD
endif
MASSPROP
END MASSPROP
many thanks,
VERSION
REVNUM 164
INPUT
include_prot yes_no
END INPUT
RELATIONS
END RELATIONS
TYPE = DATUM PLANE
NAME = RIGHT
END ADD
TYPE = DATUM PLANE
NAME = TOP
END ADD
TYPE = DATUM PLANE
NAME = FRONT
END ADD
NAME = PRT_CSYS_DEF
END ADD
add part prot
GROUP HEAD
1 Name Defined
2 Features Defined
NAME = SHAPES
END ADD
PROTRUSION: Extrude
3 Direction Defined
d1 = 177.36 (weak)
d2 = 15.68 (weak)
d3 = 77.20 (weak)
d4 = 126.50
END ADD
PROTRUSION: Extrude
2 Section Defined
3 Direction Defined
d5 = 30.00
d7 = 72.64 (weak)
d8 = 123.26 (weak)
d9 = 108.89
END ADD
PROTRUSION: Extrude
2 Section Defined
3 Direction Defined
d10 = 60.00
d12 = 189.15 (weak)
d13 = 18.94 (weak)
d14 = 112.59 (weak)
d15 = 125.49
END ADD
endif
MASSPROP
END MASSPROP
RE: pro program how to turn a local group off?
Take a look here (sequence from your PRO/PROGRAM):
add part prot
Please add ENDIF statement like this (remember every IF must end with an ENDIF statement):
add part prot
ENDIF
That was your error!
Good luck.
-Hora
