assembly rotates
assembly rotates
assembly rotates
I have an assembly that requires components that have an angle constraint. When I add the angle constraint it rotates the assembly the same amount as the angle constraint is. How do I avoid this rotation?
RE: assembly rotates
That is basically how the angle constraint is supposed to work. :)  It is usually used in conjunction with a line-to-line constraint.  Just change the value in the angle constraint.
Flores
