How to plot with a network plotter in Proe2001?
Hi, all guys,
    This is Raby.
    I'm trying to print my 2d Drawing directly through a network plotter (there's no plotter in my department, I use a net-shared plotter), but I got failed with a prompt of no equipment founded. In fact, in config.pro, I edit the plotter with the related directory of this net-shared plotter! So my question is that Proe2001 supports the plotting using a net-shared plotter? If yes, could your guys have such skills and can you share it to me? Thanks in advance.
RE: How to plot with a network plotter in Proe2001?
I think this is not a Pro/E related problem. You should be able to add your shared plotter to your computer using:
Printer and Faxes --> Add printer
from your lower left "Start" menu, or "Control Panel"
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
Thanks you all!
