AUS & ASME PV Minimum Allowable Thickness Calcs
Can anyone supply the formulae for determining the MAT of a cylindrical PV something simple along the lines of volume, pressure, temp. and material strength to Aus. & ASME codes, it is to make in-situ assessments of classes of unidentified PVs.
RE: AUS & ASME PV Minimum Allowable Thickness Calcs
AUS and US specs have simple general formulas for design ...the class of the vessel depends on pressure, thickness and what level of fabrication NDT/quality has been done
