Configurations & Dimensions
Hi all,
I was wondering if anyone had a solution or workaround for the following:
I have a Extrude-Cut Feature that has one dimension that is different for two configurations. My question is: can the tolerance be different for the two configurations? Is there any other work-around for this?
I suppose I can copy the sketch and create another Extrude-Cut feature for the alternate configuration. If I copy the sketch, can I edit it without changing the original sketch? Anyone know an easier way?
Thanks in advance,
Chris Marinelli
Thanks in advance,
Chris Marinelli
RE: Configurations & Dimensions
Another method you might try is to put a reference dimension with the other tolerance and somehow note it belongs to the other configuaration.
Regg
jevakil@mapdi.com
One nuclear bomb can ruin your whole day.
Alan M. Etzkorn
Hoffco/Comet Industries Inc.
http://www.hoffcocomet.com
Thanks to everybody who responded!
Chris
