API Call ReferenceNotFoundNotify / SetMissingReferencePathName
I'm posting for our IT department, as they are trying to write a program for people in Engineering.  Below is the problem.
example needed. We are running SW03, SP1.
I have tried a number of different combinations of basically the same code below. The simplest form I have tried is:
Private Function swApp_ReferenceNotFoundNotify(ByVal fileName As String)
As Long
     MsgBox (fileName & "Missing!")
     swApp.SetMissingReferencePathName ("D:\SLDWKS\2\24535.SLDPRT")
     swApp_ReferenceNotFoundNotify = False
End Function
I have tried this both as an add-in macro, and as a standalone .exe. In all cases, I get the same results:
    * No Error from VB;
    * The message box appears as expected;
    * The SetMissingReferencePathName call and return value have no effect.
The D:\SLDWKS\2\24535.SLDPRT file does exist, and is actually 24535revB.SLDPRT renamed. SolidWorks is looking for 24535revB.SLDPRT, but I want to give it the new name.
Unfortunately for us, the renaming of thousands of files has already taken place - using Windows Explorer. I am hoping that I can use this technique to re-establish links to the proper files.
Thanks for taking the time to look at this.
Wanna Tip? FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
RE: API Call ReferenceNotFoundNotify / SetMissingReferencePathName
Nevermind, our IT guy figured this out.  After he gets things finalized, I'll share the code.
