Passivation of 440C
Passivation of 440C
I have currently run into a problem with passivation of 440C. We have a customer who requires this material and passivation per QQ-P-35,Type II. In the spec there are warnings about possible etching when passivating 440C. We had one lot of parts processed without a problem. The next lot came back etched. The vendor says that there is no way to guarantee 440C in this process. The mix of the bath in both lots were in the middle of their tolerance, according to the spec.
Does anyone know if there is a way to control this process better to avoid the etching problem?
Thank you,
Bob
Thank you,
Bob
RE: Passivation of 440C
440C (16.0-18.0 wt% Cr, 0.95-1.20 C) contains enough carbon to tie-up all of the chromium as Cr23C6, leaving a non-stainless metal matrix. This metal will etch during passivation, leaving the dark carbide on the surface. Hence, it is essential to very rapidly quench 440C from the austenizing (solutionizing) temperature in order to maintain enough Cr in the metal phase. See Thread330-50491 for essentially the same issue.
Also, an improper atmosphere during heat treatment can ruin the material. MIL-H-6875H requires a neutral, inert or vacuum furnace atmosphere (neither oxidizing nor reducing). Oxidation is frequently a problem, depleting the metal surface of Cr.
Passivation, like many other processes, obeys the following maxim: Garbage in, garbage out.
Thank you for your response.
We currently do the following process to the material.
1. MATERIAL: 440C ANNEALED SST PER AMS 5630
2. ROUGH MACHINE
3. STRESS RELIEVE FOR 4 HOURS ±10 MIN AT 1100°±10°F
4. FINISH MACHINE
The furnace is a circulating air type.
We do not need the material for it's hardenability but purely for similar material as the bearing it is pressed onto. I thought the warning for the austenizing was in the 900 deg range. You are saying that if I adjust my heat treatment to include a rapid quench and an inert environment I could avoid etching?
Bob
See Thread330-50491 for more heat treatment details from metrat and maui.
