seed&boundary surface selection in wildfire
Hello, All,
Have you know seed and boundary surface selection method in proe2001 (or earlier)?
This method can be used for surface selection in wildfire as well, but it is not so sophisticated (based on my own experience). after selecting the seed surface, you can select the boundary surfaces while pushing shift button.
How can you define boundary surfaces as a loop surface of a surface? (when the boundaries are neighbour of a surface)
Do you know any method for this in wf? It worked in earlier versions.
Best regards:
Best regards:
Jozsef Auer
mechanical engineer
engineer in informatics
CAD/CAM Application Engineer
