Can someone explain "Auto Solve Mode" and how to toggle it?
I've got a pretty detailed profile in an AutoCAD drawing that I want to use as a base sketch for a part. When I import the .dwg (block) unto a plane and try to edit the sketch, all I can do is delete entities. If I try to drag/move a point, I get the message,
The sketch cannot be dragged because Auto Solve Mode is off.
To drag the sketch, please turn Auto Solve Mode on.
Searching SolidWorks help, the knowledge base, and this forum, turns up nothing.
What is Auto Solve Mode? How do I turn it on?
Tim
Tim
RE: Can someone explain "Auto Solve Mode" and how to toggle it?
IHTH,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
However, I'd still like to know why if it's toggled off I can't change any entities to "For construction". And I'm still not able to move the whole sketch even though no relations are "holding" it anywhere. I'd like to move it to a particular position relative to the origin.
TIm
When Autosolve is off I can cahnge me sketch lines to Construction without a problem. I cannot move them when it is off and that's the way it works. The best way I can describe autosolve (Also my understanding) is that when you move a sketch SW has to compute that entity around the origin and with it turned off SW doesn't not compute that information. That's why you need it on when you move a sketch.
Scott Baugh, CSWP
FAQ731-376
