what softwares to use in power plant monitoring ...
Can anyone help me on what software to use in a power plant?
i.e. from database, monitoring performance software, MIS software, SIS?
Thank you very much.
John
RE: what softwares to use in power plant monitoring ...
Try DMK-32 software from Lovato ( Italy ). you can look into www.lovatoelectric.com
For power system monitoring and analysis, try ETAP Powerstation: www.etap.com.
Thank you very much for the info.
Does any of you know how the ETAP powerstation compares to
other software like Etapro or Smart process?
John
ETAP is good for electrical type of info.
EtaPRO is good for electrical, mechanical, chemical, etc.
I use both, EtaPRO beats ETAP period.
Do you use PI system along with it and some other MIS software on top of Etapro?
John.
