imort acad into sketch, help
Ok, so I've read and followed the help files on inserting an autocad dwg into a sketch and it just doesn't seem to work, nothing inserts into the sketch. I am using inventor 6 with latest service packs and start sketch and use the insert autocad file command, follow all the steps and nothing inserts. Anyone have any success with importing into a sketch, could you tell me what I'm doing wrong.
RE: imort acad into sketch, help
Sometimes, the sketch will be placed way out in space...
Air cooled, belt fed, gas operated machine gun firing from the open-bolt position
Thanks for the input.
then start auto dimension, check OFF the dimension button, which means it will only apply constraints. the number of dimensions required will drop considerably. then use show constraints and you'll see it's applied a whole bunch of vertical, horizontal, colinear etc to help hold your sketch in place.
use the auto dim tool again to add dimensions and you're one step from being fully constrained...
pulling a point onto the origin, which should make your whole sketch black. then you can change parametric dimensions with (near
