Need material advice - brazing oven flights
We are using stainless steel plates as flights on a brazing conveyor
One end is riveted to a chain and stays relatively cool. The other end holds small parts and cycles up and down from about 1400 F over a period of 2 to 3 minutes.
The two areas we would like to improve are warping and scaling. We have tried alumina and ceramics but they do not survive the various shocks.
The easier they are to drill, the better.
2.9” wide
6” long
app.3/16” thick
Tom
P.s. I you wanted to quote on supplying these that would be good.
2.9” wide
6” long
app.3/16” thick
Tom
RE: Need material advice - brazing oven flights
Jesus is THE life,
Leonard
