S. VIII D.1 EXEMPTION FOR PNEUMATIC VESSEL
MY DESIGNER SAYS THAT A CARBON STEEL TANK 1m3, 30" diam, 145 PSIG THAT HANDLES AIR AT 122°F IS NOT TO BE STAPMED BECAUSE IT'S CONSIDERED INTO THE EXEMPTIONS ON U-1 (C) (6)"a vessel for containing water under pressure, including those containing air, the compression of which serves only as a cushion, when none of the following limitations are exceeded:
(a)a design pressure of 300 psi;
(b)a design temperature of 210°F"
Is this correct? because the consideration is specifically describing water, and air only as a cushion.
RE: S. VIII D.1 EXEMPTION FOR PNEUMATIC VESSEL
No, it is not. No such terms U1(c)(6) available from the latest one.
Actually it is still in the code, only it's listed now (I think since 1992) as U-1(c)(2)(f).  I'm not sure you can interpret it to mean any air vessel, however, otherwise that 'serves only as a cushion' qualifier wouldn't be necessary.  I know there's a couple code interpretations on the original paragraph, VIII-1-83-247 and VIII-1-86-13, which might clarify that.  Unfortunately I don't have access to any interpretation prior to 1989.
It falls under ASME SecVIII Div 1. If they have a problem contact the jurisdiction of installation.
