Actuator
Actuator
i need to find a economical way to operate a master cylinder for a project I am working on. I only need a inch or so of linear travel and the force required is less than 10 lbs. The voltage I have to work with is DC and can be anything up to 24 vdc. I prefer 0-10 VDC.
Greg
Greg
RE: Actuator
here are a few links:
http://www.thomsonind.com/Entry_Pages/BSA.htm
www.globallinear.com
Cameron Anderson - Sales & Applications Engineer
Aerotech, Inc. - www.aerotech.com
"Dedicated to the Science of Motion"
RE: Actuator
If you have difficulty finding a proportional actuator for your project, I may be able to help you configure something that will work. I’m assuming a stepper is out because of the need for a full-retract mode of operation in the event of a power loss – correct?
RE: Actuator
