HARMONIC FILTERS & PF IMPROVEMENT CAPACITORS
I have a Power Control Centre (415V), from which a feeder feeds around 500 kw of load of Variable speed drives (6-pulse). Another feeder from this PCC feeds a Motor Control centre having 300 KW load. To improve the PF of motors, capacitors are connected across the motors directly.
We are planning to instal a filter(4.7th harmonic tuned) on PCC to absorb harmonics from non-linear loads. However the filter supplier insists that we disconnect the capacitors connected across the motors as otherwise he cannot guarantee performance as per IEEE standard for Harmonics. What should I do ?
RE: HARMONIC FILTERS & PF IMPROVEMENT CAPACITORS
Remember that the purpose of the filter bank is to trap the system harmonics in the series connection of the tuning reactors and the power factor correction capacitors. Those capacitors installed throughout the site will cause numerous problems. A word of warning. Make sure that the capacitors used in the filter design have the capability to handle the increase in voltage due to the reactors. Failure to account for this will doom this installation to early failures from capacitor overvoltages. Also the capacitors must be able to handle the harmonic currents. I'm sure the designer is aware of these watch outs.
There are numerous references on this topic but one of the best is the McGraw-Edison-now Cooper Power Systems- book on Capacitors. See also the information in Chapter 10 of the book Power Capacitor Handbook (1984) available from Butterworths
The filter manufacturer has again reverted to us telling that as long as the total quantum of capacitors being switched in along with the motors is below 8 - 10% of Proposed Filter Bank capacity, he does not foresee any problem in meeting IEEE limits of THD(I) AND THD(V). Alternatively he proposes that the motor feeder is isolated from the main Power control centre by means of an interposing transformer or there is sufficient inductance in the cable connecting PCC and Motor control Centre.
1. Beeman, D. "Industrial Power Systems Handbook," First Edition, McGraw-Hill Book Company, Inc., 1955
Reference 1 Section "Selection and Application of Motors and Capacitors" on page 474 indicates "A recent development is the practice of connecting the capacitors directly at the motor terminals in order to permit switching the capacitors and motor as a unit. A typical installation is shown in Fig. 8.19. This unit arrangement is desirable because of the capacitors are always on when the motor is in operation. The power factor of an induction motor is quite good at full load, usually between 80 and 90%, depending on the motor speed and type of motor. At light loads, the power factor drops rapidly, as illustrated in Fig. 8.20. Generally, induction motors do not operate at full load, resulting in a low operating power factor. Even though the power factor of an induction motor varies materially from no load to full load, the motor kvars are essentially constant. This characteristic makes the induction motor a particularly attractive capacitor application; with a properly selected capacitor the operating power factor is excellent over the entire load range of the motor, as shown in Fig. 8.20, generally 95 to 98% at full load and higher at partial loads. The reason the power-factor curve with capacitor is so flat over the entire motor-load range is that the net kvar is low and varies only a little with load. The addition of capacitors for power-factor improvement does not change the motor performance characteristics, as the operating speed and shaft output depend upon motor load and applied voltage." Further down is stated that capacitor location at the motor terminal is advantageous since the capacitor and motor work as a unit, the capacitor is on according to motor needs, a separate switching device for capacitor is eliminated, etc. Apparently, the resonance issue is not a problem by a proper selection of the capacitor. Jack6238 post on Mar 24, 2001 somewhat overlooks that the total kvar of the paralleled capacitor with the motor inductance is smaller, therefore, this poses smaller problem than the motor inductance and the larger motor-inductive kvar.
It is also better NOT to have individual power factor correction on each fixed speed motor. Much better to have group correction with a detuning reactor to prevent damage to the capacitor bank due to harmonics from the VSD load.
A better solution for the VSD load would be to look at active harmonic filters (which are expensive) or look at using a Mirus Lineator patented passive specifically for 6 pulse AC diode front drives.
If you want any additional information re drives and harmonics please use my email address ; iancevans@vsdtechnicalservices.fsbusiness.co.uk
I hope the above helps.
The efficiency of the power factor here is not an issue. The effects of the harmonics, direct and indirect is.
Harmonics and capacitive pfc do not go well together.
