ASME Sec VIII Div. 1 U-1(d) - Pressure over 3000 psig
Dear All,
I have a situation here were my design is more than 3275 psig and the client insist on Div. 1. According to U-1(d) additional stress analysis shall be carried out. Besides FEA, can anyone here advised me what type of stress analysis shall I perform? BTW, my vessel is a code stamp vessel and I try to avoid using FEA.
RE: ASME Sec VIII Div. 1 U-1(d) - Pressure over 3000 psig
Brief understanding of ASME VIII Div.2
Thread292-51689
Leonard@thill.biz
www.thill.biz
Registration deadline: June 9, 2003
Classes start on June 16, 2003.
ASME Section VIII, Division 1, Design and Fabrication of Pressure Vessels
http://elearn.asme.org/courses/viiidesgin.htm
Repairs and Alterations of Pressure Vessels
http://elearn.asme.org/courses/viiirepair.htm
Section VIII Division 2
http://elearn.asme.org/courses/viiipv.htm
TRAINING PROGRAMS ON CD-ROM
ASME Boiler & Pressure Vessel Code
Design & Fabrication of Pressure Vessels
http://www.asme.org/education/disted/computer1.html
The Bolted Joint
http://elearn.asme.org/courses/boltedjoint.htm
Leonard@thill.biz
www.thill.biz
Despite all the rules that are in the Section VIII code, as long as your PE is happy with your work you have satisfied the code requirement.
Check with your PE and explain the situation. They should be able to help.
