HELP REMOVING LOAD BEARING WALL
I plan to remove a load bearing wall to open up my kitchen / didning room / living room into one big great room . I want to make sure I use the right hangers or tie-in for the job.
My architect calls for (2) 1-3/4" x 9-1/2" Micro Lam LVL beams bolted together. This new beam will be sopported by steel poles on each end. The new beam will sit on top of the existing joists.
I am wondering what type of hanger or bracket is out there for me to attach each joist to the new beam ?
My joists are not full length joists , they are 2 pieces that meet in the middle and overlap each other. They currently are supported by the wall I want to remove.
I am not sure on the type of bracket or Hanger to use ?
Please help.
Please help.
RE: HELP REMOVING LOAD BEARING WALL
www.strongtie.com
If anyone else has a suggestion ?
You could look at their straps, though, and use four straps for each joist. Just nail the strap to the sides and/or top of the LVL and extend them down to the sides of the joists. You would use 4 of them at each crossing. Should be plenty of capacity.
Thanks, Chris
If you are attempting to have a flush ceiling, the architect could have the ceiling joists hanging (with hangers)to the sides of the LVL beam. By shoring the ceiling joists a few feet away from the wall being removed (where the LVL beam ultimately goes), you can support the load and give yourself some work area. Check if the joists are blocked so there is no chance of joist rotation when you and your friends are pulling up and pushing the LVL beam into place. You will have more ceiling drywall to replace.
(I think the Taunton Book Store (Fine Home Builsing) has a book with some details of how this works).
I'm still wondering about the orignal thread. I hope the recommended LVL beam isn't above and through the bottom members of roof trusses.
Good Luck
Thanks for all the help....
Rgds
Bob
Here is the site I made :
http://s4a.homestead.com/remodle.html
Rgds
Bob
The remodel looks great!
