Froude number and Steam vent/drain
A heat exchanger that uses superheat steam to heat cold steam is being provided with drains. The drain shall flow by gravity and at the same time be capable of venting the steam (flash steam)as the drain flow downwards. Suggestions on how to proceed on the design is highly appreciated.
RE: Froude number and Steam vent/drain
Better late than never, I guess...
<<A heat exchanger that uses superheat steam to heat cold steam is being
Suggestions on how to proceed on the design is highly appreciated. >>
Take a look at: <http://fhs.ittind.com/Press/techtk699b.htm>;, Steam Control and Condensate Drainage for Heat
Exchangers. I have some other steam-related links at <http://www.PipingDesign.com/steamtraps.html>;.
Paul
_____________________________________________________________
Web-Based Resource for Process Piping Professionals
Mailing List: <http://www.onelist.com/community/PipingDesign>;
Webpage: <http://www.PipingDesign.com>;
