Office XP: runtime error '50290' Application Defined or object defined
I use a VBA add-in to write into a Excel worksheet. This add-in uses a
dll to get Real Time data from a server.
Everything works perfectly on Office 97 and office 2000.
I have an issue with OfficeXP: sometime (yes, it does not happen all
the time...), when the VBA add-in tries to write into an excel sheet,
I get the following error:
runtime error '50290' Application Defined or object defined error
The line where it breaks is:
Wb.Worksheets("Sheet1").Cells(RowNbr,ColNbr).Value = myValue
myValue is an Integer, less than 100
Wb is the workbook object
RowNbr and ColNbr are Integer (their value is less than 10)
I need help. I have looked in many newsgroups but I cannot find what
is the issue. I have a deleverable on Wed this week...
Thanks.
Thanks.
RE: Office XP: runtime error '50290' Application Defined or object defined
TTFN
