one way valve for vacuum forming platen
I need a one way valve that allows air to be pumped out of a vacuum forming platen, and closes/seals quickly allowing a vacuum to build up in the platen. I have tried a spring loaded check valve which closes too slowly allowing air flow to the back into the platen.
