A question on feasibility studies
Is it possible to have to analysis features equal to each other under the design constraints field? I want to enter angle:analysis1=angle:analysis2. My design variable is a point on a curve, lenght ratio that controls angle:analysis1. PLEASE HELP
RE: A question on feasibility studies
angle:analysis1 = angle:analysis2
Then use angle:analysis2 = xxxxx in the constraints fiels
-Hora.
Use an optimization feature to control this.
First, create analysis features that measure the angles, locations, lengths, etc. that are not represented in dimensions that control your features; which is sounds like you have.
Next set up a relation analysis feature that computes the error in what is measured from what is desired. In your example:
error = abs(angle:analysis1 -angle:analysis2)
The next feature is the optimization feature, under #Analysis, #Feasibility/Optimization. Set up this feature to have a controlled dimension or parameter that minimizes the error from the relation feature and (optionally) constrains the design. If you use the "abs" in the relation, you do not need to use the "minimize absolute value" in the optimization feature.
I use this functionality often now. It works very well. Let us know how it works for you.
Best regards,
Matthew Ian Loew
