Architectrally Exposed Struct. Steel
We are erecting a bldg. using struct. steel w/ some members that are exposed, but not designated AESS as such. THe erector is claiming an extra because the members are not designated AESS on the dwgs., even though the specs. have a section that says that all AESS welds will be grinded dowm etc. etc. THe architect is claiming that the spec. is sufficient, and the erector is claiming that he is not supposed to try to figure out the AESS members and has bid the project, as if everything was getting covered. CAn someone shed some light on this, because as the GC and the money involved, it may have to go into some sort of arbitration.
Nayeem Choudhury
Nayeem Choudhury
RE: Architectrally Exposed Struct. Steel
This is a matter between the General and the Sub. The General should control his Subs! Why is he 'passing the buck'?
