Drafting Standards
Drafting Standards
Drafting Standards
Where can I tweak the initial drafting standards;
exemple, I want to add to the ISO standards a paper format that is not normaly part of it.(e.g. want to add a XX format YYmm x ZZmm).
OR
as another exemple I want to start in ISO STDs but using the third angle projection.
The XML files dont give acces to these kinds of settings.
RE: Drafting Standards
To edit the xml files, you need to be administrator. That is start Catia up as administrator.
I have tried this. Log on as administrator snd fire up catia. I still get grayed out boxes in my standards. I cannot figure out how to get the gray boxes to edit.
Anyone have a suggestion?
bterp,
Did you logged in as administrator or did you launched Catia in admin mode (w/ -admin option)?
If you started Catia in admin mode check permissions of directory where your standards are stored.
