Scale x, y coords. indepently?
Is it possible to scale only on X or Y coord?
TIA
Dave
RE: Scale x, y coords. indepently?
yes it is, the easy way is to copy/cut your obects, then paste or insert as a block back to the drawing, when promted for X & Y scales use the desired factors. if you paste in r14 then use properties to change the X scale & Y scale as needed. (like always, many ways to do the same)
Thanks. I'll try that now.
Works perfect!
Thanks again.
