ALGOR with rubber
ALGOR with rubber
How good ALGOR can achieve simulations with non linear materials like rubber ?
I'm looking for a FEA software and I want to know if ALGOR is a good alternative to rubber-to-metal bonded parts static and dynamic analyses.
What properties does ALGOR use to characterize the compound ?
thank you
thank you
RE: ALGOR with rubber
It does support a long list of (nonlinear) material models, including several for rubber and rubber-like materials.
You can define for Mooney-Rivlin 2, 5 and 9 order curves (but you usually will get data for 2-order only, C1 and C2 constants). There is even a curve fitter in the software for your own measurements.
For Mooney-Rivlin the solution converges fast and many element types are supported. It's fun.
whcih used to calculate the change in shape. Ruber does not change in volume but changes shape. Rubber has a bulk modulus close to and approaching .5. A material with a bulk modulus of .5 has no change in volume when loaded, but has a shape change.
feapro@aol.com
