eliptical gear
eliptical gear
It might sound stupid but since I am not an expert in gears I want to ask you guys: There is any way to built an eliptical gear or any other form except a circle which can allows me to have a varaibale speed when this gear is meshing with a pinion? Don't worry about machining, it will be a plastic part.
RE: eliptical gear
http://www.sherline.com/names01.htm
(about halfway down there's an example of two eliptical gears. They actually work, the distance is constant).
You van even have square gears! McGrawHill, "Mechanisms&Mechanical Devices Sourcebook", Nicholas P. Chironis gives more examples.
You migt considder a four-bar-linkage though, simpler to make, and easier to adapt if you want to change the ratio.
http://iel.ucdavis.edu/design/fourbar/
Pekelder
RE: eliptical gear
An elliptical gear must mesh w/ another elliptical gear for two fixed centers of rotation; however they must be positioned so that major axis of one gear is in line w/minor axis of the other gear for the system to work.
