Jet A - Internal Combustion Engine
Hi Anyone Who Is Any Good (Offer educated  advice instead of rubbish)
Has anyone run a wankel engine on Jet A ?
Thanks to all,
Mr Below Mound.
RE: Jet A - Internal Combustion Engine
Yes, and No.  I am not aware of Wankel engines having been run on Jet-A specifically, but insofar as Jet-A is essentially kerosine and diesel engines run very well on kerosine, then there is no doubt that the diesel Wankel engines that were developed, would have run Jet-A quite happily.
I assume that you were asking about Wankels in a general sense, and not about a specific model.  I think there have been at least two CI Wankels.  The only one I can recall at present is the Rolls-Royce effort which had a small chamber piggy-backed on top of the main engine, so that there was two stage compression in an attempt to reach the necessary compression pressures.
PJGD
