How do I modify "dumb" solids?
How do you work on models imported from other systems?
Example: I have a model of a welded frame imported from another system and need to make it longer. Lacking parameters, in UG I would drag a box around everything that needs to move and use "Move Face" to stretch the whole thing out.
Does SW have similar capabilities? I can't even figure out how to move a solid body within a model.
By the way, I still think rough layout and concepting can be done faster on the drawing board. Any takers on that statement?
RE: How do I modify "dumb" solids?
Please look into an add in called FeatueWorks. It does automatic Feature recognition.
http://www.solidworks.com/pages/products/solutions/featureworks.html
cheers,
Joseph
To lengthen an unparamaterized tube. I would do the following:
1.) Make a datum plane where the new end should be
2.) Make a planar surface on the datum plane
3.) replace the tube end face with the new surface using "Insert-->Face-->Replace"
Like mucking fagic!
The replace face was something I hadn't used. It works.
However, imagine a goal post or a capitol H type structure, where all the solids are in one file. Now lengthen the cross member. How do I move the vertical post to it's new location? The only solution I can think off is to save each solid as a part and make an assembly. I suppose that's not the end of the world.
Don't fight the plane. Fly the plane for all it's worth and fight the opposition.
Sometimes you just gotta take the long road.
