ACCURACY OF STRESS CALCULATION - WHICH METHOD IS BEST?
I am doing a few coding on FEA using isoparametric continuum elements. I have read several books about the method of calculation of stress after the solution for displacement is available. My approach is: I calculate stress at the gauss points and then interpolate to the nodes using the shape functions. The final stress is the average of the stresses obtained from each element contributing to the node. Is my approach correct?
I have seen other proposed methods of stress calculation, such as using least square approximation from gauss point to nodal points, averaging over other adjacent elements etc.
My question is, what is the best method of stress calculation using isoparametric elements? Each method gives different answers to some extent. How do we make sure a software is giving correct stress? What are the methods available? Is my way of calculation correct?
Any help on this is appreciated with regard. Thanks.
Sudip
Sudip
RE: ACCURACY OF STRESS CALCULATION - WHICH METHOD IS BEST?
Brad
Ed.R.
Can you explain a little bit by what do you mean by "depending on how it is done"? Thanks.
Sudip
Ed.R.
