Damper mechanism for floating objects
How can I design a damper to prevent vertical movement of an object suspended at a depth greater than 15m below a surface float which is driven by the wind and the tide. There is an elastomer link between the damper and the object and I am just having difficulty in the best way to approach any design work.
Cheers in advance
Cheers in advance
RE: Damper mechanism for floating objects
Cheers
Greg Locock
Cheers
Cheers
Greg Locock
active or passive dampening?
Cheers
Greg Locock
at least colorful
