How to use Proe to do tolerance analysis?
Hi all,
   It's said that there exist a the tolerance analysis fuction in Proe itself. But I really have very little knowledge on this aspect. Is there anybody know this function? Could you share your experience? Thanks in advance.
RE: How to use Proe to do tolerance analysis?
Dim Bound function under SETUP menu. Try it!
-Hora
hi,
i am not come accross it.but i found some tips in pro/cmm module.if you have time gothrough ptc site for pr/cmmm module it has option to do the geometric analysis,hope this will help you,
regards,
prakash
go it! Thanks you all!
