inhibitor for jet fuel
Hello everybody. Does anyone knows of a fuel inhibitor? (a chemical to add to the jet fuel in order to impair itLs use in airplanes) The jet fuel will be use in an industrial process as insecticide vehicle.
a buddy of mine recommended carbon tetrachloride, but
the price is too high. What could i use instead for big
quantities?
Thanks in advance for your help.
Best regards,
Mark
quantities?
Best regards,
Mark
RE: inhibitor for jet fuel
Thanks.
Sorry, maybe the right word is not inhibit, but denaturalize.
I mean a product that when added (in small quantities,
because this is a proyect to treat dozens of tons) it will
render the jet fuel unusable for use in aircraft, but still
will burn in an industrial oven. i know that the products
that contain chlorum will break apart the engine if attemped
to use. The govt wont let you sell it as a oven fuel
if it can still be used in airplanes, thatLs why i need
such product. there are lots of products i can use, but
due to the big quantities involved, i need a cheap choice.
Thanks again!
Mark
If still environmentally compatible, why not investigate their possible use as insecticide carriers ?
